hi guys need some advice, currently having a extension built and the bricklayer has finished the brickwork and the drains have been sorted now he has started on the floor construction.
Yes i know i should have had the floor done straight after the bricks up to dpc had been laid but the builder had assured me that this is a still as good as a method as the normal way.
so here is basically what will happen tomorrow,( the hardcore and sand binding layer are down)
what he has done is cut long pieces of dpm and lapped under the dpc while the bricklaying was going on. so i assume he will be doing what is drawn in the picture above interms of the larger pieces of dpm.
My question is that is this as good and effective against the damp compared to one full piece of dpm, also will the expansion of concrete as it dries create a water and damp proof tight joint between the two pieces of dpm as shown in the picture?
Also is it normal practice to tape any dpm joints where the two large pieces have been cut to form the whole floor using double sided butyl tape and overlap tape from either screwfix or toolstation? just incase so i know as we are laying this tomorrow.
Should i use double sided tape all the way around to be on the safe side??????
What about around soil pipes how does one create a damp proof joint around them?
Sorry for all the questions, but i am real nervous about the technique he is using and have heard about some nightmare stories about damp and solid floor construction so i just want it done right.
Thanks in advance i hugely appreciate any responses..THANKS!!!!
