drain a boiler
13 Oct 2008
Glasgow
i have a small leak in one of the pipes coming from my boiler, i may have to loosen the fitting to put tape or boss white on it, if i loosen the nut it will still have water in it so how will i drain the water from the pipe to repair it ???
thanks
ps its a combi boiler
Find a drain cock on the radiator circuit drain via a hose, you only need to drain enough to reduce the pressure to Zero, use an OLD bath towel to catch what water is left in the boiler. :wink:
In Scotland most will be outside (we have mainly timber ground floors and solums)
