Drain Easy Kit - Not working
13 Feb 2006
Suffolk
Hi there,
I wanted to start replacing the old valves for TRVs on my radiators today.
I had everything ready, tools TRVs etc and was raring to go. However, I plug the necessary bits in the loft with my new Drayton Drain Easy things but I couldn't get the cold water feed sealed off properly. ie: it was allowing a trickle of water into the system.
When I take the plug out and feel arould the cold water feed hole, it isn't round but more like an hexagonal shape. Therefore I think the problem is that the plugs aren't sealing the angled corners.
Is there an alternative way of blocking this feed?
Thanks in advance for your suggections.
22 Oct 2010
Middlesex
try a carrot!! I have those bungs and sometimes don't work on F & E tanks - white nylon expandle ones are good.
22 Oct 2010
Middlesex
might do - pt it in and see - have you drained the rad 1st? what I do is then open the valve into a pot noodle carton/bucket if there is space and when the flow slows and then stops you know it's good to work on - any gurglign though and be quick!!
13 Feb 2006
Suffolk
Just bunged the hoses after turning boiler off etc and then opened the bleed screw as per the destructions.
Just waiting to see if the trickles stops now as before the water just kept flowing out.
22 Oct 2010
Middlesex
if i'm changing a rad valve on o/v system what I do is: bung the feed/vent
drain the rad (using drain kit and collar)
open rad valve to be changed and wait until flow stops
change valve
13 Feb 2006
Suffolk
Hi there,
the parsnip worked!
I just bunged the system up, drained the rad and then changed the valve.
New TRV works a treat.
Thanks for the veg suggestion, who'd have thought it!
15 Nov 2005
Crossgates, Europe
Cook Islands
you can also use a carrot to remove the base of a lightbulb if the glass has broken. Just push it firmly into the base and twist (power off first of course)
28 Jun 2005
the parsnip worked!
Well, you could have knocked me down with a Orbignya cohune :eek: ..............................................Tropical American * Feather * Palm :mrgreen:
13 Feb 2006
Suffolk
Hi there,
now that I have all my TRV's installed, what temp setting should I use for the room thermostat in the hall (no trv on the hall rad) and as my boiler has 0 - 5 settings only, what should I put that too?
Cheers
15 Nov 2005
Crossgates, Europe
Cook Islands
and adjust the setting by not more than half a point a day if you find a particular room a bit too cold or a bit too warm. Leave it for a couple days before you alter it again.
21 Sep 2008
London
Just wait - in a few hours a new post will appear: "HELP - CH PIPEWORK BLOCKED WITH VEGETABLE MATTER..."
MJN
30 Apr 2008
Wiltshire
Ah... So it's true then what they say about carrots helping you see in the dark then?! ;)
Mathew
6 Sep 2010
Avon
Just thought that I should mention the fact that, if the hall thermostat switches off when it reaches temperature this will switch off the pump and all other rediators would cease to work.
Why not fit a trv to the hall and just leave the bathroom rad without one?.
