Drain pointing cement tone
17 Apr 2007
I'm attempt to match the Yellowish paving colour with the pointing cement using Motartone Buff colour but its not working as the photo shows.
What cement mix would I need to match the paving colour?
full
Thanks for posting.
So Snowcrete mixed with soft sand (which is yellow) and buff mortar added to get the colour?
building sand would probably be easier to match the colour with .
you wont need much dye . trial and error
It seems the most cost effective way is to get a 25kg bag of snowcrete.
So none goes to waste, can white cement be used like portland grey stuff for other cementing/concrete jobs?
Yes you can use snowcrete for your other jobs as it has similar properties to normal Portland grey cement..just whiter.
I have some red tile roof pointing to do as well so perhaps white cement in ideal. Until starting this thread, I didn't know it existed but then, I'm not a builder.
Before you take it up,try spraying some bleach on surface to dull it down a bit, it will also weather in time,so not as noticeable.
Our local plastering sand (fine sharp sand) with ordinary grey portland cement dries to a closer colour than that. Id make a few test mixes up of various sands you can get.
