- Joined
- 9 Dec 2020
- Messages
- 7
- Reaction score
- 0
- Country
I need to move the existing radiator pipes due to an upstairs bathroom renovation as we are relocating them for the install of a new radiator.
I have isolated, drained and removed the radiator, however after mapping out the piping one of the pipes is long enough to be 'bent' to the new location as the pipe is over long, but the other pipe needs extending. I am note certain without experimenting which is inlet and which is return.
So a simple relocation has become a cutting of the pipe, and attaching the new pipe structure i have created quickly using a JG Speedfit straight coupler at the point of cutting and my new pipework.
My guess is, even with heating turned off, I will not be able to cut / cap without a mass of Bar 1.0 pressured water shooting out the pipe so I need to drain the boiler
However the pictures of the Worcester 8000 in the manual show the drain valve but it is literally not on device where they say it should be, it appears in a dotted circle but gives no guidance on where it is, and in every single video of plumbers ogling and stroking the Worcest 8000 is there not a single one who takes a breath and says 'now to drain, just attach this hear and pull this' and 'to fill it press this'
Can anyone advice please on the process you would follow to drain the system after turning it off.
