Hi all,
We have recently completed building a summerhouse about 40m away from the main house. It is on a slight downward slope (summerhouse lower and main house higher) but not by much, half a meter tops. We were thinking about getting a macerator pump that feeds into a sump then back upto the main drain of the house. This is a father son project and I was discussing which pipe we are going to use for the drainage from summerhouse to main house. This is where my father mentioned to use 32mm waterpipe (the blue stuff) and he said diameter is not an issue as it will be pumped. Now im no plumber but I have been to Greece on holiday a few times and they have drainage problems with 40mm waste pipe i.e. dont flush the bog paper. Would it be better to use 40mm waste pipe or maybe even bigger?
The pumps we were looking at are made by pegler. The trench has been dug and we are ready to install the drainage. I just want to make sure were going down the right track.
Any help or advice is greatly appreciated.
