Hi All.
I've just moved into my new house and have been having problems with the kitchen sink drain in the kitchen which is part of an extension that was added.
The sink was not draining properly, so I used a drain cleaner to see if that sorted out the problem. It didn't and the drain needs plunging every couple of days.
I lifted an inspection panel in the utility room and found out my problem. See the picture below.
My question is: what would be the best way of running the pipe?
I did some digging around and found they recommend a 20mm drop per metre. I was under the impression that I shouldn't drill a hole in the joist, Is this correct and if I can do, should I laminate around the hole with extra wood.
Thanks in Advance
Mark
Thanks in Advance
Mark
