Hi
Just had a CCTV survey which shows following:
Ground floor toilet to IC soil pipe is cracked underground and needs replacing
Gully cracked and needs replacing.
The issue is, there is only about 10" of room between the side of the inspection chamber and the outside of the wall where the toilet is. The toilet soil pipe disappears into the concrete floor in the bathroom and reappears at the bottom of the IC (approx depth 1m).
A drainage company are advising that the easiest plan would be to take down the side of the IC and rebuild the entire thing in precast concrete, new PCV piping easier to route properly as there is only 10inchest to play with. Caveat being they don't really know whats what until excavation.
My question is - is the toilet pipe drop of 1m likely to be inside the house (beneath floor/foundation) or should it come out of the wall at a high level and then drop down on the outside? Reason I ask is, I would plan on excavating and exposing existing so that we can get a better idea of routes, space, etc.
Mike
Mike
