Draining the System
8 Mar 2006
West Midlands
I want to drain my open vented conventional CH system to remove rads and flush out the sludge...have found 3 drain points on the system....intend to turn off cold feed to expansion tank and then drain system - anything else that needs to be done before commencement?
Manually open the 3 port valve .........if you`ve got one :oops: little lever on the side and it locks in open posn.
