i have a limit of £200 pounds for a new table saw, I am thinking of getting the draper 82571 table saw, will only be doing general diy.any body any thoughts on this machine. or any that any one has used. thanks.
no sheet materials. mostly decking boards. have had a look on ebay, heck of a choice. saw the draper, and Ryobi, both second hand, both look as new. thanks for your help.
if your cutting planks to length you need a mitre saw not a table saw
he could be cutting short lengths less than say 800mm for say rabbit hutches or furniturePresumed he'd be ripping them for edging? Unless that is the case. Mitre saw is the way to go.
What about a table/mitre saw combo for best of both worlds?
Jack of all trades - master of none, I'd say. You need to compromise on the blade for a starter - a blade which gives you a neat crosscut will often bog down or burn on long rips, a nice fast rip blade will be as rough as a bear's whatsit on crosscuts. Then there's the time/fiddle element. When you flip from crosscut to rip you need to undock the riving knife and reposition and lock it, then fit the crown guard then the dust extraction. The process is done in reverse when going the other way. It's tedious and slow, so you need to box clever and plan every cut to avoid wasting 5 minutes each time you change modes. Also if you are in a tight position you also need to swing the saw round 90 degrees every time you change mode so you can get the timber across. As said above - pricey.What about a table/mitre saw combo for best of both worlds?
