- Joined
- 15 Dec 2021
- Messages
- 5
- Reaction score
- 0
- Country
Hi Community,
I hope you can help with this one..? My Ideal Isar HE24 recently failed. Hot water, but no heating. Home insurance sent a man - he said the LP711 timeswitch was at fault and did a temporary fix as an override. So now, when the boiler is switched on the central heating is on continuously regardless of thermostat setting. hot water is delivered on demand. I bought a new LP711 timeswitch as a replacement part. When I look at the backplate - image uploaded below - there are two wires connected. A black wire (LHS of the image) from the cable going in to the boiler, and the blue wire (right hand side of image) taped off with insulation tape.
What I don't know is how the engineer did the override. I have contacted him but he hasn't responded. I assume the override is at the backplate (as opposed to inside the boiler - I don't think that would make sense??). Would anyone like to suggest if the black and blue connected cables is the override, and if so, which slot they should go into. As I think you might expect, positions 1 and 2 are HW/CH off, and 3-4 are HW/CH on. I presume one of the other two cables in the trunking comes from the thermostat (wall mounted dial thermostat in hall) but I couldn't tell you which one. Any advice gratefully received.
