Drayton MA1 Valve not allowing heating and water at same tim
Thanks - as the valve moved, then this seems a logical conclusion - I don't have a multimeter, so I guess will have to call in an electrician
thanks for your help
My advice would be a heating engineer, many electricians are not conversant with CH wiring. Agree a no fix no pay deal, or there might be an engineer on here in your neck of the woods that may be willing to help.
Are you 100% sure that you understand how the thermostats will turn off the boiler when either the room or the cylinder reach the set temperature?
Hi Tony,
I think so.
If I go back to basics
The boiler is on waiting to go into action
If I have just the heating on and the thermostat down - nothing happens, if I turn it up, the boiler bursts into life and heats the radiators
If I have just the water on, I can do the same by changing the thermostat on the cylinder
So when both are required, sometimes it works, sometimes only the water side works. I did think that the cold may have something to do with it, but we noticed it first in the mornings, when both needed, but no central heating came on
Do I need to know any more?
Do you have TRVs on the rads?
It might be a balancing problem!
If all the rads are actually heating it may be dragging all the heat from the cylinder ???
Without being there to see exactly whats happening its difficult to guess.
If that was directed to me, I do have a rough idea on their operation. :wink:
