Drayton mid position valve staying warm/hot when heating/water not turned on
6 Sep 2020
HI all
Hope someone can enlighten me on if I have a problem or not really.
I'm not a plumber but "like" to think I have a half decent amount of common sense?? lol
Immersion heater stopped working and mid position valve was seized at mum and Dads place so thought I would help out and have a go.give advance warning that the hot water tank could go....and sure enough it did lol
Changed tank/cylinder and complete valve and all works perfectly with no leaks,hot water kicks in when it should,valve switches between H..Mid and W as and when required......
Now for the head scratching part which I cant find a definate answer for.........when heating and water are off(as in not requested).....the valve electrical box remains quite warm even though pipes are cold , the valve position is in H....I'm guessing something is staying switched on but is this SUPPOSED to work like this???.... my thinking is if it does work like this somethings not gonna be working for very long
Any advice please......cheers :)
15 Aug 2010
Livingston
No when no demand the valve should go to W not H, you have not wired the HW off wire correctly, it should be connected to satisfied from the Cyl stat and HW off from the programmer
18 Oct 2007
Kent
I have to disagree. If the valve is in the CH only position and CH is satisfied or turned off, then the valve will stay in the CH only position until either the power is turned off at the switch controlling the heating system, or there is a call for HW.
View media item 31084
CBW
26 Sep 2019
North
So the last known call, eg heating, only stays in heating until satisfied? Then springs back after ch off at programmer?
8 May 2017
If everything is functioning as it should ,i.e boiler runs as it should for c/ heating and domestic hot water ,under the selected functions of the programmer ,then you would appear to have wired up correctly.
The 3 port valve will be warm ,and remain so ,under certain conditions even when the boiler is not operational and nothing calling for heat. Pretty much as laid out by D.Hailsham above.
  • Thanks
Reactions: CBW
6 Sep 2020
Hi guys...thanks all for the replies...valve switches fine between all settings on demand or on timer....if water is last command it will stay on W and will be fine....if last call is for heat...it will stay on H and only then it seems to get warm.....even after half hour or so when pipes have cooled down....if that helps better to explain my brainteaser a bit better...have read MOST people say this is normal....but never noticed it on my own one at home....cheers guys :)
6 Sep 2020
Sorry...me again....tank stat has been replaced to and cuts in and out fine as drained the tank a bit to make sure it was doing what it is supposed to do :)
(My dads water bill be a bit bigger this month lol)
8 May 2017
Quite normal with Y plan set up. It will stay in that position , indefinitely, until the programmer / timer settings are changed. The motor will continue to draw a small amount of current during this mode ,hence the heat.
6 Sep 2020
thanks terry...just got home and my one at home does same aswell.. so guessing all good...
just seems wierd to me that something should be left on when nothing required....amazed they last
as long as they do
3 Feb 2008
Northamptonshire
I always advise people to set the timings to switch the CH off before the HW, which should encourage the valve to return to the 'Rest' position whenever possible. As said, the Valve will continue to draw a small amount of current to hold it in CH position even with CH off until it gets a command for HW and moves the valve again. In 'Rest' position the valve is sprung return to be open to HW only.
