I have just replaced the mid position valve in my gravity fed central heating system as it was partially seized. When I came to fit the valve control box which came with the new valve I noticed that the wiring for the old control box had the white wire not connected to anything. The wiring diagram which I had showed that this should go to the thermostat.
The system had been working fine up until now with the hot water and central heating coming on and going off when they should so I put the control box from the old valve unit on the new one. They looked identical anyhow.
The system works fine now but I am at a loss as to why the white wire is not being used.
The thermostat is a British Gas RS2 which I understand, from some info I found, can have two or three wires connected to it. The initial wiring installation was done by a qualified electrician but he did take over six hours to get it all to work.
So to summarise, I don't really have a problem as everything is working fine but would like to understand how it works.
