Drayton Tempus replace with Nest Heatlink
I will check all wiring again, hope can find out the answer...
Cylinder thermostat is it mean the Nest thermostat?
Do you mean this big guy? Where can i find the Cylinder thermostat? I have no idea of it as i only use combi boiler before.
The big guy picture.
Yes that’s the one, it’s behind the grey box, so unlikely that you’ve lowered it. Did you heat the cylinder up already?
I have checked the wire, and seem not problem.
I have use the "testing heating" from Nest thermostat and it is work, the boiler status show "C" and burner light was on.
I am thinking if the heat function okay, the only possible problem of wire shoulg be the one at Nest terminal 6...
And i find that there is no hotwater testing on Nest thermostat, only heating, is it normal?
The cylinder may heat up because my wife truned on the hot water function with the old programmer this morning for showing, maybe i need to test it again tonight?
Sorry, posts overlapping. Yep, wait for it to cool down and then test and report back.
I found the problem finally.
i use this type of connector for connecting some of the wire together, and i have change the connector to a new one, and it's work!
I don't know how to say but just want to let you know i am really thank you for your help.
