Drayton Wiser 3 Channel Installation with Complex Existing Wiring
10 Oct 2026
Hello friendly forum users.
Our heating system is in need of update and I have purchased a Drayton Wiser Thermostat Kit 3 system (WT734R) with the hopes of being able to carry out the installation myself. However, I turn to you requesting some advice on untangling the complex wiring system that appears to have developed over the life of the house's heating system.
Some background on the system as far as I am aware. It's ~100yo house and at some point the old cold feed tank was taken out when the loft was done and a pressurised system installed being an Ideal Logic+ System 30. There was one heating zone and and the wired thermostat was replaced to be controlled by a Boss Therm BRTRF wireless thermostat and BR1 receiver. Approx. 20 years ago an extension was added and a new cylinder was installed in the extension (Vaillant VIH GB 210S) along with a new heating zone controlled by a Danfoss RX1 wireless thermostat covering the extension areas. This was paired with a Horstmann 425 Tiara programmer also installed alongside the new cylinder. In order to make the link with the new elements of the system within the extension it appears a second wiring centre was installed linked to a third wiring centre in the extension via a 7 core flex.
The heating system has always had issues, particularly in controlling it, wherein at the height of summer, with no apparent demand for heating, the radiators in the extension would be red hot with no way to turn them off via the thermostats. Now the rotating dial to set the temperature on the Boss thermostat has completely fallen off (it was connected via a piece of plastic no more than 1mm diameter so a miracle it survived this long) and is stuck at 4 degrees!
I have mapped the existing wiring layout which is represented in the following diagram.
I believe if the system had been a simple S plan system with 2 zones with the wiring all neatly as expected I probably would have been able to get to grips with it but with the ad-hoc nature of the wiring I am somewhat struggling to get my head around how it is operating and how/where I need to intervene to remove the existing heating controls and replace them with the Drayton Wiser system.
Drayton Wiser wiring:
Any assistance would be much appreciated. I am ready and able to provide any further information on the existing system that may be required.
Thanking you in advance.
Terminal 3 of zone 1 doesn’t appear to be connected to anything. With regards the Drayton Wiser, locate it next to wiring center 2 and utilise the connections from the Tiara decommissioning that in the process. You then need to provide a switch live from the Wiser to control zone 1, decommissioning the boss receiver in the process. You may need to link certain wires together, so that nothing is left open circuit.
Hi CountryFan, thank you for your reply.
As regards terminal 3/zone 1, I double checked and that is how it's been wired. Looking at the wiring diagram from Wiser I presume it is equivalent to the white wires which it notes to be wired to a spare terminal (16).
With regards the Wiser I don't think locating the Wiser next to wiring centre #2 is the most physically feasible. There is the boiler, zone 1 valve and wiring centres 1&2 all located together in the old part of the house. Then a length of 7-core flex runs about 15ft somewhere through the floor to a cupboard in the extension with the cylinder, HW valve, zone 2 valve, programmer and wireless receiver for zone 2. I believe to get those linked back to wiring centre #2 according to to the Wiser wiring layout I would need 14 cores i.e. running another 7-core flex which I am not sure how easy would be.
As such I've looked at whether I can link the boiler side equipment to a new wiring centre at the position of wiring centre #3 via the existing 7-core flex with the Wiser next to it.
I've come up with the following - does this look correct:
Hard to follow, but I think it looks correct. In your 1st diagram, there’s is no 2nd wire in WC1/Zone 1 terminal 3, whereas there isn’t now, so should be ok.
Been busy so apologies for the delay and thank you for the response. I'll hopefully be getting round to this at the weekend. Was checking over the wiring diagrams for the various components and just wanted to check on those for the cylinder. The Wiser diagram has the cylinder as COM (C) to 15, CALL (1) to 14 and SAT (2). The Terminals on the Vaillant cylinder are numbered 1, 2 and 3 with a brown on 1, blue on 2 and nothing on 3 - would I be correct to assume 1 would be equivalent to COM (C) and 2 to CALL (1)?
Check that cylstat 1 to N (any known N in the circuit, not the blue in the Cylstat) is 240V when HW is demanded by programmer.
Your diagram appears to show boiler is wired with 240V external switching throughout but be aware that some Vaillant proprietary controls use volt-free switching.
Important not to wire 240V to boiler extra low voltage terminals.
Thanks for the advice polesapart. Looking at the existing wiring it appears to be part of the mains wiring. I also tracked down the manual for the Unistor:
Everyone using different numbers/letters in their manuals doesn't help but comparing it with the existing wiring 1 should be the HW on from the programmer and 2 is the call to the valve so should be equivalent to the C (com) from the Wiser and 1 (call) to the valve on the Wiser manual wiring diagrams. Fingers crossed I've deciphered it all!
I have tried to follow the plan, but seems you have already got it working?
The one point is
I had something similar with mothers house, and it should not have been possible without two faults, one had to be the wall thermostat which would need to fire the boiler, and also the TRV had to be faulty as well so water could go into the radiator.
Hi Ericmark, yeah got it up and running at the weekend - everything seems to be operating as intended just the signal from the hub in the extension to the thermostat in the old part of the house is a bit weak but still works.
As regards the heating in summer issue, I did wonder if it was maybe something to do with the programmer calling for heat even when the thermostats weren't or something about the way the pipework was extended that was interfering with hot water to the cylinder? If it was a dodgy thermostat or programmer that's now all been removed so hopefully there should be no more calls for heat in the middle of summer when its 30C!
I found following what the central heating should do was easy to get wrong, with my own I have two motorised valves, so the main house and flat can be independently controlled, but they share the same boiler, but not the same pump, and the micro switch is single pole, so only real option is to have a relay, so I have one set of contacts for the pump, and one for the boiler.
So the first thought is if a design fault or a device fault, I only have one relay, so can run house without flat, but not flat without house. But I don't often want to do that, so not a problem.
Both mine and mothers house we had two thermostats in parallel. Her house IMGP8038.jpg two lights on the hubs, which showed if running or not, mine not so easy, yes two hubs Thermostats_tonemapped.jpg but in the flat, where not easy to monitor. But I can hear the boiler running, so aware if there is a fault. So to find why the boiler is running, there are five options.
1) Nest Gen 3 set to run DHW.
2) Nest Gen 3 set to run CH.
3) The wall thermostat had activated the Wiser hub.
4) The TRV had activated the Wiser hub.
5) The flat thermostat has turned on the heating.
But although boiler running will always heat DHW, to work CH also the TRV heads must have opened to flow to some radiators, I know DHW will only run for 20 minutes, so any thing over 20 minutes has to be CH, but I have no sighting of any by-pass valve. So even with all TRVs being off, there may be a flow through some unknown by-pass valve.
So only way I can forward from this, is to feel the temperature of pipes, it is clear I have something allowing transfer of boiler output to boiler return without going through any radiator, so somewhere I must have a bi-pass valve, or pipe.
However not a clue where, so next question does it really matter? The heating works, so why fiddle, my boiler is not a condensing type so unlikely to improve efficiency.
However in the same way as I have looked at my central heating, you need to look at yours.
