Drayton ZA5 actuator - where to buy replacement microswitch
21 Apr 2020
Hi there,
I believe the microswitch on the Drayton Za5 hot water valve actuator is goosed, as it is keeping the boiler firing up when the valve is in closed position and all programs are in "off" status. I fitted a multi-plug connector to it to save having to disconnect bits and bobs at the terminal block every time I am fault finding or changing out stuff. When plug connected, pump runs and boiler fires up although valves for central heating and hot water are both in the closed position.
Unplug the Za5 and all stops.
I have googled to find a replacement microswitch, but getting no joy. Any guidance on where to buy and part number would be great.
Thanks.
28 Oct 2005
Daventry
The microswitches aren't an official spare part - you'd normally just buy the whole head
21 Apr 2020
Thanks,
Seems crazy to spend £60.00 - especially in the current climate - when I can spend around £5 for a replacement microswitch and replace it myself.
27 Jan 2010
Buckinghamshire, Darn Sarf
Search for Honeywell microswitch (I think it's a V7 version, but check your old one to make sure...I believe they are slightly smaller than the Honeywell valve's V3).
When soldering the wires use a soldering iron; I've found using a blowtorch makes a bit of a mess.
18 Mar 2017
Wales
Microswitches are standard electronics items. Note the shape/dimensions/voltage/current ratings and check sites such as Digikey/RS/Farnell to find a substitute.
30 Dec 2018
Ebay too are a good source.
