Dribbling shower
3 Dec 2004
I've just moved into a new house with what looks like an electric shower unit from the 80's! When you turn it on the water just dribbles out making having a shower impossible.
I've never had an electric shower before - can I just go to B&Q and buy a new one and get someone to swap them over or is there anything else I should consider?
Any advice gratefully appreciated.
Simon
To consider....existing cable size,breaker or fuse capacity,kw of proposed shower, pipe entry, and if anyone rang me and said they had a Gainsborough shower bought from B&Q to fit, I'd tell them where to go.
Hi Solo,
Ive just bought a Gainsborough shower bought from B&Q, any chance you could fit in for me? :D
Just wondered whats the prob with Gainsborough Showers? they just a poor make dangerous etc?
Reason I ask is ive got one :( please be good news!
Gaz
I found them flimsy and the case was a b*****d to get on. Might have changed now but they are on my don't do list.
Hi Solo,
I've had a look at the current unit - it's called Triton and says 80W underneath.
Would I be best getting someone in to give me advice?
Ta
Simon
I have had problems with Gainsborough in the past too.
Go for a Mira or Triton the higher the kilowatt the stronger shower but the cable has to be up to grade 10mm for anything above 9.5 kw.
Pete
Hi folks,
I've managed to get the front off.
There are two pipes coming into the unit (one hot and one cold I guess!) and a grey electric cable.
Because of the two pipes (and my homebase bathrooms) catalogue, I'm assuming a need a mixed shower and that this will work without replacing any wiring.
Would this be correct?
Simon
You guess correctly you have a mixer shower with an electric pump.
All you need is a replacement wall pump the cable size only relates to electric heated showers.
Best going for the same model as the piping and electric cable points will be the same or very similar.
You will have to isolate the hot and cold feeds and of course the electric current at the consumer unit take the fuse out or trip the mcb and make sure no one touches it while you work on the shower.
Good luck
Pete
Cheers Galena1,
I wasn't sure if I could have a power shower. Are there any electrical requirements? Is it likely the cable going into my current unit will be ok (or does the cabling only really apply to electric showers?)
Ta
Simon
