Drilling Holes for Curtain Rails, Cant Drill into Lintel
25 Oct 2011
I have a 1960's house with large windows and what seem to be heavy duty lintels.
I am trying to put up curtain rail/pole brackets but I cant drill the holes because the lintels seem to be incredibly solid.
I have used a masonry drill, a drill on hammer setting and normal setting.
Does anyone have any advice on how to get the holes drilled.
Bin that drill and go for sds - as the other guys said - they can be got relatively cheap from diy stores - they revolutionised the building industry years ago :wink:
Have you checked that it is not a steel lintel, like a Catnic? If it is, SDS will not touch it.
Steel can be drilled with an appropriate bit, drill, speed and patience :wink:
you really need to get up high and put presure on the drill, if it is a steel lintel then you need good quality drill bits like Dormer / SKF
Wotan
