Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
It's no good - I'm going to admit defeat and ask for an explanation, as I can't see how you end up with a ceiling void on each side of a lintel above an opening in an external wall.....
Perhaps void is the wrong term. To avoid running the pipes along the wall or ceiling, I wish to feed the pipes from the boiler in the extension, up into the 'space' above the ceiling plasterboard then through the lintels into the 'space' above the existing ceiling, and from there up into the airing cupboard above.
Good idea, I'll have another look at the plan to see if that is feasible. I think it will depend on the total height of the lintels plus the tray above which bridges the cavity.
