I wish to install the climbing training board (pictured below) on an internal load-bearing wall, above a door to our sitting room (also pictured below). 4 screw holes in the board to mount it. I’m thinking of first bolting a piece of wood to the wall of circa 18mm thickness and then the board onto it, to get more clearance from the architraves for my wrists. Board dimensions:
width: 48.5 cm
height: 21 cm
thickness:6.5 cm
What are these internal walls typically made of? What sort of lintel? The house was built circa 1982 and the total thickness of the wall is about 130mm with plaster.
Will this compromise the structural integrity of the wall?
What screws/bolts and plugs would you recommend?
Any other tips?
Thanks!
width: 48.5 cm
height: 21 cm
thickness:6.5 cm
Any other tips?
Thanks!
