drilling/screwing into end grain of wood
5 Dec 2012
Hi, I'm building a timber frame for log cabin using 2x6 timber and they will be joining forming a 90 degree angle at corners.... Therefore to join together I will be screwing through the side of one piece of timber, but into the end grain of another piece... Would this provide enough strength?
Thats fine but are you not using posts at corners?
as an aside
end grain wont hold screws as well as across grain so countersink and pilot but not the end grain for up to no12/6mm screws at least
Thanks for replies. I have been advised for log cabin it is best to build the frame and literally sit it on top of the timber legs/pads, rather than bolt it to the side....
as an aside
So countersink and pilot across grain but no pilot going into the grain?
yes definately don't pilot
dependant on what screws you use piloting may not be needed across the grain but safer to make sure the head is sunk so components sit flat rather than held apart by a proud screw head
