Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Ideally a tile bit, but masonry will do. Don't use the hammer action.
Measure up, place tape in location of hole, then mark the tape for hole, the tape will help the bit from slipping and scratching tiles.
Low speed on rotary action, be patient, once you are through tile and if the wall behind is masonry, you can then but into hammer action, if using tile bit, change to masonry bit when through tile for holing wall.
