Drip where ribbed dishwasher outlet pipe joins sink waste?
2 Oct 2010
Essex
Having just re-connected the outlet tube from my dishwasher to the spur / "fir tree connector" at the kitchen basin waste (just above the "S" bend - I have a small leak. It drips abut half a cupful every 30 minutes if the dishwasher is working.
Hopefully the picture is visible below.
The problem is that the pipe is not a tight fit over the connector. So even if I tighten the jubilee pipe clip at tight as possible, water can still drip.
I thought I could replace the pipe with something a bit narrower at the end but I wondered if there was an easier solution ?
Thank you
http://s630.photobucket.com/user/he...s[user]=90807354&filters[recent]=1&sort=1&o=0
IMG_2093_zps4464119c.jpg.html
It would be nice to see that connection turned uppermost or at least horizontal, if such a thing is possible.......failing that, dry everything, add a good smear of silicone and reconnect.
John :)
Thank you John.
I went to my local PM to get some silicone and also bought a new piece of plastic with a wider diameter. This screwed in to replace the previous bit.
All is now snug and drip free. I also applied a coating of silicone.
(I wish I knew the name of the part so I could describe it better)
Thanks - all is now dry
