- Joined
- 2 Jun 2016
- Messages
- 4
- Reaction score
- 0
- Country
Hi to anyone reading this...
So, I'm going to put this into real Laymans terms because I don't want to confuse the matter. I am at work at the moment so can get more specific details/pictures later. I just want to get the ball rolling.
There is a small pipe on the front of my property that is constantly dipping water, about 2 drops per second. This is happening constantly. When I leave for work it is dripping, when I get home from work it is dripping and it is dripping when I go to bed. I have never seen it pour, only drip.
I have been in the loft and there is a small black box, it has what looks like a bin liner wrapped around it. I am lead to believe this black box feeds water into a large container (big foamy looking guy) that is almost directly below it in the wardrobe of my main bedroom.
Now...Having googled possible issues, I have ruled out a leaking Ballcock. I have emptied (almost completely) this black box off all water. When I do this, water is flowing into the box, filling it up until the floating ball reaches a certain height and it stops completely. I have held my hand and pieces of paper around the end where the water is pumped into the box to see if it was possible spraying in and I couldn't see it, but no leaks were noticed.
There is also a pipe separate from the box that aims into it. I believe this is a hot water vent. I don't understand exactly what its function is but I have a feeling it is the culprit.
BUT, I had a plumber in to see if he could sort the issue. He replaced a thermostat on the big foamy guy. There are two on the big foamy guy, a 'Boost' and I guess the other is just a 'Normal' one?
The plumber seemed to think that the thermostat was not switching off, heating and expanding the water up the pipe into the box and out the overflow. It seemed to work but only for a few days.
Anyway, the pipe drips onto my porch roof and I'm worried it will damage the structure.
I hope you have read this far and the information I have provided makes some sense at least! Please help and tell me its an easy and inexpensive fix.
James
James
