I have a smallish rear garden ~9m/9m which is significantly below the ground floor of the house (slope from front to back of property). Due to other building developments around my property I've managed to get planning permission to deck the entire rear garden to my properties ground floor height.
A large part of the area under the deck will be head height, therefore I'm contemplating adding some dry storage here. I had thought I could wall off a section of the head height area, use corrugated roofing material under the deck and send the water into a soak away (opposite end of deck).
My builder has raised some concerns, as he feels:
- dirt/debris falling through the deck will eventually block the roof and water will sit there. This will eventually cause the roof to fail.
- Since the entire deck will also be enclosed by two boundary walls, one boundary fence and my properties rear wall, he feels it will be damp under there and that will eventually work its way into the enclosed area. (Total under deck area will be 81 sq/m, enclosed area about 10-12 sq/m).
It's going to be a costly project, as the rear boundary wall will end up almost 4m high (fortunately the side wall is mostly already that height as the neighbour has a raised deck already). Therefore if possible I would like to get some extra storage out of it as well if possible. The additional cost of building the storage area is negligible compared to the overall project cost, so I think its worth a try. But I'd appreciate any advice to give it the best chance of success. Or should I heed his advice and just drop the idea :/
Appreciate any thoughts, thanks.
