Dry verge quandary
14 Jan 2008
Staffordshire
Hi all!
Need a bit of advice - I plan to fit some dry verge to my house, but the gable over the front door terminates in a valley on both sides. Trouble is, the verges finish on half, not full tiles.
How do I get around this? Is there a shortened dry verge tile that I can get, or do I have to get all creative with a hack saw?
And if the hacksaw route, any suggestions for capping the open end to stop creatures setting up home in my roof?
Thanks in anticipation : :)
Quite right, when the Dry Verge comes down to a valley you do have to get creative.
Blocking the gaps has to be equally creative, sometimes (depending on type of plastic) you can overcut and fold; or utilise a piece of eave comb filler; or any other method to suit your particular tile/verge
Good luck
Thanks all - confirmed my suspicions :)
Next part then - my one gable end doesn't terminate in a ridge, but the (double roman concrete) pantiles finish at the chimney stack. The chimney "wall" is flush to the main gable end, with the verge standing a couple of inches proud of the gable end. Again, how would I finish that end?
I'm guessing that there may be some detail other than a ridge cap that I can buy,but failing that, I thought that I'd probably have to finish the end by overlapping it with a bit of lead flashing.
Yes, you need to extend the chimney flashing to cover the top of the tile
