Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
We've built an new kitchen extension and need to dry line it. Using 8x4 boards should we put the boards upright floor to ceiling or sideways and have a brick pattern? Any pros and cons of both? Its a 24ft by 12ft kitchen.
Fixing the boards vertically is standard practice; if you don’t have access problems & the ceiling is below 2.4m I can’t see any practical benefit in fixing boards on their side. Having a horizontal join across the room on the centre noggin rather than just a series vertical ones every other stud may be less desirable for skimming but admit that on odd occasions where I’ve done this, it hasn’t been a problem.
