S
Soggy_weetabix
Do any other plumbers out there use it?
In years of using it ive had pin holes, leaking boilers (gaskets), daincocks, valves but never has it eaten through an iron fitting. As plumbers, every leak can be adressed but if this stuff can pin an iron fitting I have the opinion if can destroy a cast iron heat e/ex.
On this one, as with so many, mains pressure (or powerflush) will have pushed off spreaders on the twin entry m/bore vlvs so I didnt mains it.
The system is so bad It was sludging pumps in 3 months.
Basically, Im of the opinion every rad needs off to clear sludge now. I have 2 inches of heat on either side and across the top.
Magnaclean ready when the system is clean!
Putting one in my house tommorow...great invention.
David
David
