- Joined
- 13 Dec 2017
- Messages
- 2
- Reaction score
- 0
- Country
I recently discovered a leak coming from the large nut on one of my rads. I tried to nip it up but it would not move. I looked online on how to resolve this issue and thought it would be relatively simple. So, first I unscrewed the nut carefully to allow the water to come out. After around 20 mins the water stopped. So, then I tried to take off the large nut but it would not move. At this point I was advised by a friend that this type of valve may not have a olive under the large nut. And was advised to wipe then end of the joint to remove any debris, which may have been causing the problem. I then found a small brass object which I can see has come out of the actual valve on the opposite side, (tap side) There is a threaded bit on this brass looking piece which looks like it screws into the bottom of the dome shaped valve inside. On the opposite side (radiator side ) a black plastic tube is protruding out slightly.
Firstly, is there a special tool to re-insert this small piece back in? and secondly where does this plastic pipe fit to?
Any help or advice would be welcome.
attached pic of same type of valve
