- Joined
- 18 Feb 2007
- Messages
- 1,400
- Reaction score
- 79
- Country
Can anyone offer any advice regarding the Selection of Dual Fuel or All Gas Cookers
I see that most suppliers offer Dual Fuel as an option.
Why there is an option puzzles me because if you have gas to the hob it would seem obvious for power cost reasons to use Gas for the ovens, but I must be missing something here.
My question is that heating by Electric is approximately 5 times more expensive than Gas per kWh, therefore it seems to me that Gas ovens are the cheaper to run by a factor of 5.
I may be misunderstanding the power consumption of the two choices in that an oven cavity may typically be 1 kW. To provide this energy by electricity would cost five times as much as Gas, but of course this may not be the full story.
An electric oven will consume typically 1kW whilst heating up the cavity, but of course when up to temperature the Electrical supply will be switched off or at least modulated so that the energy actually being consumed will be only effectively the heat losses the oven radiates externally. This is the same for the Gas oven but as the power supplied is modulated, when up to cooking heat temperature the total power consumption in say 3 hours will NOT be 3 kWh but substantially less than this due to modulation of the power source.
If one considers a typical usage of an oven would be say 10 hours per week which equals 10kWh and therefore 500 kWh per year.
Typical costs for Electric power is 13p/kWh and gas 3p/kWh. the difference being 10p/kWh, the difference in cost for the supply of this energy would be around £50 per year which is not insubstantial. But if modulation is taken into account then the difference 'may' come down to maybe £20 per year which is more acceptable.
I have no idea what the Modulation Factor is for these devices and asking the question to manufacturers does not produce meaningful dialogue.
This begs another question which is:- Is the electrical power to an oven Modulated (similar to gas in that the gas supply is turned down as the oven heat up) or is the electrical power supplied either On or Off? i.e. Bang/Bang control
Has anyone any advice or figures relating to the cost of using an Electric oven to Gas oven.
The information would be very useful to me when choosing my next cooker.
I need to decide on fully Gas or Duel fuel and the Cost of use is the determining factor.
It would seem to me that if I have a gas Hob it would most cost effective to have Gas ovens also, but if I am right the Oven manufacturers would never produce Dual Fuel Cooker.
Hope this makes sense, but I need advice from some one who know about these issues as clearly I have no idea at all and can't get manufacturers to engage in a discussion.
