2500sq ft house built during when things are good. The building regs wherent great, 50mm aeroboard in the cavity. 50mm fibreglass in the attic spaces. I have upgraded to 250mm fibreglass in attic voids and in the living area, dining and kitchen i have installed 75mm insulated plasterboard. Will be upgrading to external insulation next year and getting the house air tested to find leaks.
I have upgraded to a 30kw solid fuel stove however it hasnt been connected to the cylinder yet double coil cylinder. The house is already plumbed in for oil to a single coil but will be upgrading to double coil soon.
What i want to know is, is it possible that i can set it up that i can only heat downstairs instead of all over and when needed i can call for the heating upstairs when needed rather than running about the house turning off valves etc... . This is a large house and i would only need heat in some rooms rather than heating the full house.
