Dulux Satinwood paint reacting!
7 Dec 2012
Warwickshire
We're using Dulux Satinwood paint for metal and wood. It's the water based one and not the solvent based variety. It seems to react with the paint beneath it especially on factory primed MDF. I think we're going to change what paint we're using so I'm looking for recommendations. We used to use Dulux Once solvent based but found it yellows too easily. What do you use that is water based, non yellowing and has a satin finish that will not react with primers and fillers?
I’ve recently been using this paint
and the accompanying primer
to paint bare wood and bare mdf. 2 coats of the primer and one coat of paint has gone on fine. Haven’t tried the paint over factory primed mdf yet.
Have also used the paint to recoat painted wood. Gave it a good sanding and paint went on fine, but took two coats. Can’t comment on its durability/aging.
If painting over a previously painted surface that has had some 'history', sometimes I am tempted to clean and sand, the use a solvent-based undercoat, before applying the water-based.
Just really seal over all the old stuff, and to cover the primed mdf.
You need to be sure the solvent-based is properly dried or cured before using the water-based ideally.
