Dunlop 2-Part Rapidset Flex
17 Feb 2008
Berkshire
would this be the best to use on a ply overlay as oposed the normal flex adhesive? Any ideas how much area the 11KG bucket covers?
whyme!
this should help
COVERAGE
9.3kg kit of DUNLOP 2-PART RAPIDSET FLEX will fix approximately 2m2 based on 3mm bed depth (depending on trowel used).
11.55kg kit of DUNLOP 2-PART RAPIDSET FLEX will fix approximately 3m2 based on 3mm bed depth (depending on trowel used).
i'm laying on 12mm ply, what would you recommend? most fllor trails are 9mm are they not?
Use either a thick bed solid bed trowel or a solid bed tipped trowel; either trowel will give a finished bed depth of approximately 4mm once the ribs are collapsed.
Dunlop Set Fast Plus
Plywood Overlay:- use exterior grade plywood (at least 15mm thick) which should be screwed down at 300mm centres to an existing timber floor to ensure full support. Prime with a suitable primer such as DUNLOP UNIVERSAL BONDING AGENT.
If the overlay is less than 15mm thick then use Dunlop 2-Part Rapidset Flex.
