Hi
I have the same problem with my DWF A10 Whirlpool dishwasher. Our problem started after a plumber came to clear our blocked drains. Afterwards, I noticed that the dishwasher was full of water in the bottom. I bailed out as much as possible, but it didn't work - have the two green flashes. I tried adding salt but no luck. I tried switching off at the socket and back on, but again no luck. There's definitely water in the hole in the centre of the base of the machine, and in the salt hole. However, I can't follow your advice to pull the machine out and tip it back to drain, because the machine is fixed in. Any other suggestions please??
Many thanks in advance
Fiona
Fiona
