Dyeing laminate
26 Oct 2006
Hi. I am getting a retail premises done up that already has laminate flooring laid by the previous owner, however it is the wrong colour. Does anyone know if I can use a dye over the laminate - and what will be the process to do this? Or will I just have to cut my losses and lay new flooring?
hi,
does anyone know if it is possible to dye laminate floor darker or will i have to re-lay a new floor ?
thanks
K
heeelllooo keelinover and welcome :D:D:D
if its the cheap stuff this is only chipboard or mdf with a paper printed desighn with a plastic coating so no not realy [in my opinion :wink: ]
if its more expensive stuff with real wood veneer usualy around 12mm thick you have a chance to remove the finnish and re colour
but as the veneer is so thin your unlikly to remove all the finnish before you remove the veneer
and if you dont get all the finnish off youll get patchy results
having said that if you can disolve rather than sand the finnish you may be ok
but nothing in my opinion will work on the photo printed cheap stuff
good luck
