Earth . . Apparantly?
7 Sep 2006
Birmingham
(thanks to all who left comments in the recent thread by david_galashiels, it was very educational.)
Can anyone solve the mystery of the seemingly under sized earth bonding?
Note from the pic if you can (sorry only taken with cam/phone today) that a 16mm earth is fed back from the CU(not shown) to the main earth block which then has bare wire returning to the lead outer of the phase and neutral -(sweated across both) tn-s earthing I presume. The locking screws of the bare wire on the earth block are sheared off. Also into this earth block connects a smaller earth from elsewhere, this is along side the 16mm and is my be 4mm.
My question is, the wiring has been updated and a new CU fitted, with new earth cable back to the block, but the bare wire from the block is considerable thinner/smaller? I know I'm thinking in terms of gas pipes and this just wouldn't work. Sorry thats not really a question is it?
O.K. try this, I'm there to sort the multipoint (you can just see it with case off left of pic) new o/heat stat, sorted. Then like all good gas persons check bonding on gas pipe 10mm, yes good, follow bonding back to earth block or in this case CU earth strip then back to earth block and BAM my 10mm regulation bonding disappears into thin wire sweated on/ pins sheared, I cannot even lob abit'o spare 10mm into the block.
I have pics now of three 'jobs' in which the identical situation exsists, Large earth then reducing to thinner fixed wire.
Right you've waited long enough my question - is it acceptable?
If NO...
I know we spoke about PES, DNO It gave me PMS but can I earth strap round the already exposed lead and run to a new multi block then 'lob abit'o spare 10mm into the block to sort my gas pipe out'?
Cheers Lads.
The un-insulated earth sweated onto the lead cable sheaths is the property of the electricity board, and sized according to their standards.
They have supplied you with a terminal to use (the old style one), and this is where YOUR installation begins. Everything after that point must comply to BS7671. Anything BEFORE That earth terminal is at the electricity boards discretion.
If you contact your DNO, they may well upgrade the earth connection for you.
I would always opt to stay with a TN-S supply, I hate to see PME supplies derived from a TN-S service.
thanks lecky & spark,
yes I realize thats the stock reply but I'm still curious.
securespark said
What's your Ze?
So if its not then, whats the options, can it be done safely with out involving the ODPM - Joke!
