Earth Clamps for Armoured cable
Due to a restriction on the entry point into the supply area it is virtually impossible to fit a standard earthing gland assy
Is there a none damaging clamp that can be used to link up the outer sheath to the CU , normal bonding clamps will crush the inner/outer cable (Bit of a Spoonerism)
The cable is 6mm SWA and has tested at inf on 500v from sheath to earth.
Tom
Tom
