So I've recently had drainage and a water supply installed into my garage (to move the washing machine & tumble dryer in there). The water supply is blue plastic pipe in the middle with copper on both ends.
There was already power in the garage supplied from a spur in the kitchen, an there's no problem with that (so I am told)
However, one thing that has come up is the fact that the copper in the garage isn't bonded.
The electrician I am using to check over the house say that the bonding needs to go right back to the CU.
I understand a little about why bonding is necessary but I don't understand why you can't simply (possibly stupidly) ...
* connect the copper in the garage to a local spike or ...
* connect the copper in the garage to the supplied earth or ...
* connect the copper in the garage to the copper in the kitchen
... which all seem a much simpler and less ugly solution that going all the way back to the CU which incidentally is the other end of the property!
