earth fault
Greeny said:
its only a couple of hours drive from birmingham can't you come down and see if the bonding has been done outside of my flat?????
no problem, I am on the way
Greeny said:
if it is a live to earth fault why isn't the breaker tripping? i'll have to check whether there is still voltage there when i turn the fuse board off, im sure i did check that when i turn't it off and there wasn't any voltage?
The fault may not be a direct short, it could be incorrectly wired appliances or sockets. An MCB will not clear this type of fault, where as an RCD is more likely to.
pick some beers up! if the sockets are incorrectly wired i.e neutral in the live wouldn't this trip it?
the breaker? so is it probably down to my sockets not being connected properly???
It is possible, amongst an array of other things.
i'll bond the pipes then check all the sockets to make sure they are connected properly hopefully that will sort it, cheers
In areas of high load (brum), there is always a high chance of 'perceived shocks' due to circulating network currents - if your main bonding isn't satisfactory, this becomes a problem.
On Yer bike!!
You haven't said if this AC or DC. I know its obvious to you but all factors have a bearing.
Have you any ELV lighting?
Is it present when all but the Ring breakers are made?
The advice you receive will be in direct propotion to the info you give.
Qedelec said:
On Yer bike!!
I also didn't see page two but my comments stand.
dont see how you get a shock from 12v? Didn't think that was possible unless you're licking the sink :oops:
