Supply company came out got a horrendous reading somewhere on his side,changed my earting arrangement to pnp ? fitted a new earth strap and bobs your uncle prblem solved and impedence reading now down to 0.12
the earth "strap" is a jubilee clip secured round the iron pipe coming into the house carrying the supply cables.The earth cable is secured to the pipe via this jubilee clip.It does'nt look as bad as it sounds as the pipe is quite large 50-60mm in diameter and may be too big for a normal earthing clamp.
