Same as before.what earthing/bonding is typically necessary after metal water service is replaced with plastic.
TN-S supply? //www.diynot.com/wiki/electrics:earthing-arrangementsThe main elec service, in this case, has 3no earth clamps to a very old lead and fibre kind of wrapping.
a plastic supply pipe cannot introduce an earth potential into the equipotential zone
if it's INSIDE the plastic pipe, how does it come into contact with earth?
get a 1m length of hosepipe, fill it with water and stick your megger in each end set at 250V.. see what its resistance is..
it's not an earth potential if it's several hundred ohms above earth due to the length of the plastic pipe before it encounters some metal to conduct to earth
4.7 in the OSG says no need to bond metalic parts supplied by plastic pipes..
