Easiest way to build a small retaining wall
17 Aug 2004
Hi all, after some advice on building a small wall/retaining wall.
here is the garden i did 7 years ago now and the wood has just gone rotten, even the posts :(
As you can see, i need to do this properly. I lay foundations and build a wall, but i don't particulary like the look of all the brick that will be on show once it's done. Arse there other alternatives, like for example i have seen concrete slotted posts and then gravel boards dropped into them, at least this way i can paint the boards etc, the wall are not really retaining anything as such so wondered if this was an option?
That's what I have at the back of our house. 3 concrete posts with 3 concrete gravel boards stacked between them.
It was there when we moved in 9 years ago and is still doing the job. If I could see it I might be tempted to cover it with something.
