Easy mount hinges 90 degrees
23 Jan 2010
London
Easy mount hinges 90 degrees screwfix,what is the max thickness door for lay on or inset door thankyou.
Jason thanks,but i cant see where it says what is the max size door thickness ,only the carcase.If i used 2x2 as a side frame i wonder what the max size door thickness i could use thanks.
18-19mm would be about the max with layon. Your 2x2 wont be deep enough for inset.
Jason
Thanks jason ,i was thinking of laying on the door ,could this mean i could increase the thickness of the door as there is no door next to it cheers.
