TracyTaz said:Right, I'm feeling full of confidence now my sink is working like a dream. I'm seriously thinking of changing my shower tray as the one in is a very poor choice of colour.
Is it simple enough to replace a shower tray? If I've replaced a bathroom sink will I be up to it?
I assume it has some kind of wooden frame underneath, but I'll be able to simply remove one tray and replace like for like on the old frame. I think I'll have to silicon round the edges and round the waste pipe (or use a shower-tray-mate!) I can't think of anytning else assuming the trap is still okay..?
Glad you feel this way, however changing a shower tray isn't as easy as replacing a wash basin. Have a look at the tutorials on this website one page gives full details on how to install a shower cubicle. Feel free to browse through and conclude then whether the job is feasible.
http://www.dynomo.co.uk/Fit a shower cubicle.htm
I guess the problematic factors you will face are firstly, removing the existing tray and the glass shower enclosure without causing any damage to surroundings, all remaining sealant on tiles etc will need to be chemically removed so that when the new seal is applied, it will adhere to the tiles. I don't think you will be able to replace the tray itself without removing the glass panels. Although possible, is definitely something I wouldn't recommend. Having said that, it might even be worth your while replacing the whole shower enclosure itself considering you may well have to rip out the entire old one.
The trap will need to be identical to the existing and will need a thorough check once fitted to ensure of no leaks.
Personally, I'd advise you call in a plumber or even try a handyman from a local paper, fitting a shower cubicle is not as easy as you think it may be. From removing existing, to securing new, making sure there are no leaks through the enclosure, working with silicone for the first time and several other issues, this job will become a nightmare if you go wrong somewhere down the line...
