- Joined
- 12 Feb 2011
- Messages
- 7
- Reaction score
- 0
- Country
Hi
My engineer (fully qualified), has repaired my Vaillant Ecomax 835 (7 years old)
This required a 3rd PCB
He now wants me to pay for the 2 PCB's he has had to buy
It seems the issue was the neutral wire coming from the supply
This seems to have caused a short or blown the PCB
problem was established when he called Vaillant directly who advised him to check electrical supply
I am not happy, that at £ 165 each i have to pay for these 2 PCB's
My issue is this
Why would PCB's need replacing for such a simple fault
Please advise what i can do
I feel that the design or manufacturer of these should have a fail safe / fuse that would prevent such a simple and common failure
Is the engineer at fault for not diagnosing as well
Why should i pay...
Also, it is likely that the resistor, varistor or component that has tripped or blown due to the neutral wire being loose , is only pennies in cost
I have the 2 PCB boards and would like to know if Vaillant will re-imburse me
It is likely you can easily be repaired and resold.. These PCB's are still very popular
My issue is this
Why should i pay...
