Hi all,
First post and domestically limited, so go easy I have a problem for which I'm not sure how to best resolve, and I've not found anything searching the forum.
I live in a 'one-up-one-down' flat, with heating supplied through three Economy 7 wall-mounted heaters. All has been fine for the 5 years that I've lived here; however last Saturday morning I woke up to find my living room heater had not heated overnight.
Hoping (vainly) that it was just a one off, I adjusted the settings to a different temperature for the next night's heating; however, sure enough, the next morning the heater was still stone cold. At this point, I switched it off at the wall, and started to find any information I could
The other two heaters (in the bedroom and hallway) are heating happily as normal - so I'm pretty sure it's not a central problem. Also, there was no sign of degradation from the living room heater leading up to it failing (i.e. it didn't pump out less and less heat over the previous week).
Does anyone have any experience of this? Barring having the ability to wire a 3-pin plug and change fuses, I'm not knowledgeable with electrical problem-solving.
Could it be a fuse in the wall-mounted switch that's died? Or will I likely have to buy a whole new heater and get it fitted? I'm keen to get it sorted asap, what with more snow being forecast next week
Here's a picture of the switch and heater for what it's worth - in case there are numerous types of switch
http://www.jaiyan.com/heater.jpg
Thanks for any help,
Lloyd
Lloyd
