and power taken from the grid
so I know the split tariff works for me. Your first job is to work out which tariff suits you, as by changing tariff to a single rate day and night, you may need to do nothing. If I did not have solar and a battery, split tariff would not suit me. The smart meter app
may also show when you use power, that is your start point.I assume you have a reason for the change from off peak to instant heaters? Storage heaters are still madeGot rid of old storage heaters and replacing them with new generation of electric heaters.
why have you not replaced with new storage heaters?Thanks for the quick reply. I’ll send more photos tomorrow. I do NOT have an immersion heater, but I appreciate the concern.Yes, that is the way it works. Need to see the fusebox/consumer unit arrangements. Basically you need to connect the off peak live to the 24 hour live. The place to do that is not in that cupboard. The isolation switch is sealed and I bet the "contractor notice" says something useful, but cant read it.
Lets have a look at the consumer units inside. Need to be careful because you may have an off peak immersion heater- and you dont need that running 24/7.
When you've changed the feeds, you need to cancel that off-peak tariff. The 24 hour costs are usually higher if you have an off peak tariff.
Electric Radiators with WiFi controlledAre they electric heaters or electric storage heaters
Storage Heaters in my opinion are old fashion and also, more important, they occupy a lot of space due to their size. New electric radiators are 100% efficient and they can be remotely controlled.Off peak supply is an old idea, but is has evolved through the years, and also varies from supplier to supplier, pre-off peak I was paying 29.57p per kWh with 62.21 p per day standing charge, moving to off peak (5 hours per day called EV rate) peak is 31.31p per kWh and off peak 8.95p per kWh with 59.14p per day standing charge. As the off peak time get longer, we tend to see a raise in price, there are 7 and 10 hour deals as well as my 5 hour deal.
However there are some histrionic tariffs where the peak rate has not risen as much, so one has to be careful, as often one can't return to those tariffs once you move away.
It also varies area to area, I live in mid Wales.
As to the big 4 power users, the washing machine, tumble drier, dish washer, and immersion heater, they are also not cut and dried, my dish washer can only be delayed by even hours, and others start with ½ hour increments, but as time increases go to hour increments, the washer and drier also tumble the clothes every so often while timing out, so using the blue ball of soap in the drum does not work.
Often there are 2 immersion heaters at different heights, lower one off peak, upper one peak, using just the upper one I found weekly use was around 2.5 kWh so they don't use that much.
If you use a constant draw on power, then duel tariff can still work out cheaper, the problem is if you use more power during peak than off peak, OK for me, my solar power software gives me a good graph of power used, View attachment 357731 and power taken from the grid View attachment 357732 so I know the split tariff works for me. Your first job is to work out which tariff suits you, as by changing tariff to a single rate day and night, you may need to do nothing. If I did not have solar and a battery, split tariff would not suit me. The smart meter app View attachment 357740 may also show when you use power, that is your start point.
Also need to consider the future, babies really change power use.
I assume you have a reason for the change from off peak to instant heaters? Storage heaters are still made View attachment 357744 why have you not replaced with new storage heaters?
often uses water storage, as it allows many heating systems to heat the same space, this shows one tank, but in real life it is often two very large tanks, on a reinforced floor to take the weight, and can only really be used when built, the same applies to a hot air system, with a central brick store, unless in the original design really a non starter.Yes, that is the way it works. Need to see the fusebox/consumer unit arrangements. Basically you need to connect the off peak live to the 24 hour live. The place to do that is not in that cupboard. The isolation switch is sealed and I bet the "contractor notice" says something useful, but cant read it.
so already running for over 5 hours per day. Not really that bad, as once return water is hot, the boiler turns off, even if thermostat still calling for heat, a lot hinges on your life style, so arrive home 6 pm, put the dinner on, go for a shower and turn up heating would be a problem, but by staggering use, it is doable.
both with a clamp on, and smart meter in home display, (IHD) the phone app (from smart meter) and solar app are to slow to respond, and I know my 16 x RCBO consumer unit although in theroy could overload the in my case 60 amp fuse, it is highly unlikely, but I have oil heating.If you need to find a tradesperson to get your job done, please try our local search below, or if you are doing it yourself you can find suppliers local to you.
