Ecotec Boiler Firing Up the Heating
1 Nov 2017
Hi
I have an ecotec 831 combi 24kw hooked up to a honeywell wireless thermostat.
Seems that the heating kicks in even when I have set it not to, making the house constantly warm and wasting the heating bill.
Theres 10 rads in our 4 bed house.
Ive set the heating to 60 degrees and water is working fine.
Radiator symbol flashes and the up arrow in the small circle is also on from time to time. Seems to be anticycling.
I saw that changing the D0 setting could be the answer (it's set to 24) but don't know what I should change it to.
Could it also be a miscommunication between the wireless thermostat and the boiler?!
Anyone have any tips to get this to behave?
Much appreciated
It was here when we moved in. The wireless thermostat is new. I have tested that and all appears to be reading correctly.
Simply a case of the boiler switching the heating on when the demand isn't there...
Should I try anything else?
Thanks @hertsboilers
I called Vaillant who were also mystified when I talked them through the situation and checked settings such as D0 (which they said is correct to set at 18 not 24).
Perhaps a simple wiring issue so will call the engineer back.
Your previous post doesn't make sense. An 831 is 31Kw. Not 24.
The bottom of the boiler states 24kw i reckon here is the label...could be wrong as I'm not an expert
cid:B0519763-D9D7-4B9D-982E-776353B366E2@lan
