While I appreciate it may be difficult for anyone to say without seeing it, but wondering if anyone can help locate the central heating draining point in my flat. The plumber I had out was not sure - think he is not used to older flats.
System, I think, needs a good flush and cleanse and flush and inhibitor put in. Had a combi boiler installed last year that failed about 9 months later and the engineer said it was probably due to sludge and muck in system. The system does take some time to heat up but has no cold spots on the radiators or anything.
As I say, the plumber I had to look at it recently to service the boiler and talk about doing this work was used to more modern houses, I think, and not sure where there might be a drain point or how to drain system. There is a valve with a pipe that leads off towards the front of the flat. When opened, the boiler started losing pressure, but not sure where this pipe might lead (it definitely doesn't go back into the system, anyway). Is this likely to be a drain point?
Can anyone advise? I'd rather not get another plumber out just to look and the plumber that installed the boiler does not, I think, trade any more and does not answer his calls. Should say though, that I don't think he's dodgy and we were pretty happy with his work.
